Re: Expon bug in wp34s Message #4 Posted by Andrew Nikitin on 13 July 2013, 5:01 p.m., in response to message #2 by Marcus von Cube, Germany
Since I was there, I think that similar bug in Expon_u should also be fixed.
I tried this one in console emulator.
Index: trunk/xrom/distributions/exponential.wp34s
--- trunk/xrom/distributions/exponential.wp34s (revision 3429)
+++ trunk/xrom/distributions/exponential.wp34s (working copy)
@@ -43,6 +43,8 @@
SPEC?
JMP cdf_infinite
[times]
+ x<0?
+ JMP ret_1
e[^x]
xOUT xOUT_NORMAL
@@ -55,6 +57,8 @@
SPEC?
JMP cdf_infinite
[times]
+ x<0?
+ JMP ret_0
e[^x]-1
@@ -70,7 +74,6 @@
xOUT xOUT_NORMAL
expon_param:: RCL J
- GSB check_special_pos
- RTN
+ JMP check_special_pos
Edited: 13 July 2013, 5:01 p.m.
