Re: program print in wp34s Message #12 Posted by Andrew Nikitin on 15 July 2013, 4:26 a.m., in response to message #11 by Marcus von Cube, Germany
Marcus, I checked it on a device. I started printing program from the menu, immediately pressed r/s and kept holding it while it printed. It printed entire program (about 20 lines) to the end with me holding the r/s all this time. It was uncorrected firmware, so all stops in the code showed up as "RUN", but, obviously, it does not mean anything. Printing could have been completed in the fraction of a second before I hit r/s, and the printer could have been printing from the buffer, but i doubt that. I think I have set a half a second delay between lines.
Emulator, on the other hand, does not allow key press at all: once you start program print, and then click on r/s, the click will not register. Or at least, it does not look like it, button does not change appearance as it usually does upon click.
BTW, on the hp-42s press-and-hold for r/s shows the program line where the program pointer is, not "RUN". I checked it with free42 emulator, but manual says same thing.
