Re: go41cx and forth rom? Message #5 Posted by Garth Wilson on 15 June 2013, 3:10 a.m., in response to message #4 by 'Angel Martin
Is it the same one described at http://sense.net/~egan/forth41/forth41_v3n45_p29.pdf ? I was not aware of this module until recently, and I was not into Forth anyway until about 1989 (I got my feet wet on the 71 which did not have a very good Forth implementation either), so I never had this module; but it looks like it takes away nearly all the RAM, does not use standard text files for source code, and is awfully slim on functions, even for 4K. That's not to say he didn't do a good job with what he had to work with. He apparently did. The 41's hardware design does not seem conducive at all to Forth. I would kind of like to have Forth on my 41cx, but probably not without modern additions of much larger RAM and probably 41CL speed for the editor (as the 41cx text editor might be prohibitively slow for this). My type of work might have me a bit tunnel-visioned, but I see Forth having its greatest value where you want a lot of real-time, fast, direct-access I/O bit-twiddling, a description which again does not match the 41. The module might however give someone a big headstart to improve it now that modern hardware additions could allow a much better one.
