Re: HP 85A. GET and SAVE commands. Message #2 Posted by Patrice on 3 June 2013, 4:24 a.m., in response to message #1 by inaki
Did you set the switches in the ROM emulation module ?
From memory, it should be easier to use IO ROM and redirect serial input to keyboard.
Otherwise, there is windows software to read/write on floppy disks
The HPDir Project and a long time ago, I used an Agilent utility called LIFUTIL.
Edited: 3 June 2013, 4:27 a.m.
