Voyager Self Test Message #1 Posted by Mike (Stgt) on 16 May 2013, 5:05 a.m.
One of the self tests for Voyagers (HP-10C, -11C, 12C, -15C, and -16C) is for key board and display segments. It is startet with the calculator off by pressing the '/' key (upper left corner), hitting the ON key (lower left corner) and then releasing the '/' key. The display shows four segments "lit" (well, they are black or visible). To pass the test you must hit now all keys _once_ in sequence (only the ENTER twice, just in "it's" row), going row by row beginning with the upper left key. At every key press the display changes, showing four segments in the first row and all but the last key only two segments.
Question to all with access to a real HP-10C _and_ other Voyagers: comparing the display step for step, are the same segments lit on both Voyagers?
Questions to the experts: are there differences within the Voyager series regarding the display? Yes there are, but is there more out there than Erig's highly valuable variants list, especially about the display? A manual about the Voyager's self tests could help I assume. One more: are there ROM revisions?
TIA for all your effort
