Re: HP 39gii Tutorial: REPEAT and WHILE Message #7 Posted by C.Ret on 20 Mar 2013, 6:35 p.m., in response to message #5 by Eddie W. Shore
Eddie you are welcome.
No problem at all, I consider this code has already fallen into the public domain since I posted it this public forum. It was the result of a kid of brain storm threat. Several people were involved in the discussion. Gilles is one of them.
Please feel free to publish it, as soon as you are kind enough to indicate references of the peoples and the Silicium.org forum.
www.silicium.org/forum
[hp39gII] Simplificateur de racines carrées
([hp39gii] A Square Roots Simplicator)
The HP-39gii is really an amazing system. Every day, we discover new capabilities; the localization and initialization in one shot is one of its numerous features.
The Silicium.org forum is really active, we already analyze this first version of the code and turn it into two new versions :
EXPORT RAC(X)
LOCAL F:=SIGN(X), R:=ABS(X);
LOCAL I:=1,Txt:="¡Ì("+X+")=";
REPEAT
IF R MOD I*I
THEN I:=prevprime(I);
ELSE F:=F*I; R:=R/I/I; I:=FLOOR(¡ÌR);
UNTIL Q<2;
IF (ABS(F)<>1) OR (R=F) THEN Txt:=Txt+ABS(F) END;
IF F<0 THEN Txt:=Txt+" i " END;
IF R<>1 THEN Txt:=Txt+" \V"+R END;
RETURN Txt;
The only change is prevprime(I) replacing I:=I-1; expecting speed-up with large numbers.
The last version, is quite more different, it is using the built-in function ifactors that returns the list of prime factors (and multiplicity). This last version has the shortest/fastest look-up loop !
EXPORT RAC( X )
LOCAL F:=SIGN(X),R:=ABS(X);
LOCAL p,I,T:="¡Ì("+X+")=";
LOCAL LF:=ifactors(R);
FOR p FROM 2 TO SIZE(LF) STEP 2 DO
I:=LF(p-1)^FLOOR(LF(p)/2);
F:=F*I; R:=R/I/I;
IF (ABS(F)<>1) OR (R=F) THEN T:=T+ABS(F) END;
IF F<0 THEN T:=T+" i " END;
IF R<>1 THEN T:=T+" \V"+R END;
RETURN T;
Edited: 20 Mar 2013, 6:40 p.m.
