Testing card reader motor for 65 Message #1 Posted by Michae Altmann on 17 Mar 2013, 6:27 p.m.
The card reader in my HP 65 isn't responding at all. I removed the back and unsoldered the wires attached to the card reader motor. Then I used jumper wires to bring 3.5V to the motor, positive where there was a red wire. I get no response. That seems indicative of a burned out motor. Right? Or is there some way that it jams up? The rubber wheel will also need replacing, but it doesn't seem worth taking everything apart if the motor is dead.
