Re: WP-34S Integration Message #13 Posted by Paul Dale on 6 Mar 2013, 11:19 p.m., in response to message #2 by Walter B
When I replace build 3363 with v2.2 build 2738, it runs significantly faster (<2s). Seems the price for having a lot of free space in flash memory.
This is not the reason at all. The algorithms used by the two different integration routines are completely different. Version 2.2 firmware uses a non-adaptive Gauss-Kronrod quadrature. Version 3 uses an adaptive Romberg method. The former makes exactly 21 function evaluations and returns its result. The latter can do hundreds or thousands of function evaluations.
For well behaved, relatively smooth functions the Gauss-Kronrod method is better -- it is exact for polynomials of degree 20 or less (forget the precise order). For less well behaved functions, Romberg is better. As usual things are a trade off.
The space saving changes essential to version 3 firmware have not created orders of magnitude of performance loss. Sure, they slow things down but not nearly by as much as you see here.
- Pauli
Edited: 7 Mar 2013, 5:09 a.m.
