HP-25 keyboard Message #1 Posted by Brad Barton on 15 Feb 2013, 4:44 p.m.
I've been lurking here for several years now, and have enjoyed the discussions on all aspects of HP calculators. However now that I've acquired some older models, I find myself in need of assistance and have finally registered.
Among my new problem-children is an HP-25. I fussed with the contacts for a while, and sent off for some new 1.2V NiCads and repaired the battery box. I finally was able to get it working, but it's not very reliable.
I must admit up front that in my excitement at my new toy, I was dumb enough to plug the unit in to the charger without a battery in place. However, I seem to have gotten away with it, because when I put my voltmeter on the charger terminals it only registers about 1.8 VAC. So hopefully a bad charger has saved the 25 from my own stupidity, and preserved the ACT chip from destruction.
The problem now is that the display acts erratically. It always displays 0.00 when I start it up, but once I enter a number the decimal points act in the opposite manner that they should. The decimal that is supposed to be illuminated is off, and all the others are on.
Also, the keyboard does not register the number 1, and also has a bit of trouble seeing a "divide" command. Plus most of the time when I press 4, I get a 6.
I'm hoping that the keyboard problems can be fixed, but there's not much information here on the dis-assembly of the Woodstock keyboards. I did read a recent thread where the author used a combination of vinegar, water then alcohol to cure a non-registering key.
Can anyone tell me if a problematic keyboard could be the source of the strange display problem? Further, are there any links you could point me to that show how to safely disassemble a Woodstock keyboard?
There appear to be at least two melted plastic studs at the upper right and upper left of the back side of the keypad that would need to be carefully drilled out. Is there a preferred method of doing this so that proper re-assembly is assured?
