Re: [41CL]Updating ROM images with a Clonix Message #6 Posted by Diego Díaz on 11 Feb 2013, 2:34 p.m., in response to message #5 by Dan Grelinger
Hi Dan, all,
As usual, I pick up the thread at a very late stage, when most ideas/solutions have already been posted. However...
Dan, from your post I think that you're trying to use a .ROM file from an "external" directory. Just to point out: the .ROM images used to configure any of my modules *must* be placed in the same directory where the ClonixConfig utility is running from.
This is stated so in the ClonixConfig user manual, at the end of the "Installation" chapter (pg. 2):
"Some files have received new names like ClonixConfig.exe, Flash06b.exe or Flash12b.exe; so you can still keep the previous versions if you want, or just erase the old ones.
Please note that these files must be in the same directory where your .ROM image files are."
Hope this helps, please do not hesitate in mailing me or post in case my understanding of the trouble was not accurate or you need further assistance.
Best wishes... still from Caribbean :-)
Diego.
