Re: magnetic strip malfunction Message #6 Posted by Dan Lewis on 13 Jan 2013, 8:51 p.m., in response to message #1 by aurelio
Aurelio, you should check out this little article on repairing pre-recorded cards for the HP-65, 67/97 and 41C.
How to Repair Pre-recorded Cards
I just finished restoring an HP-65, and I've found this method to be helpful on a number of occasions when a prerecorded card didn't work.
I put one piece of scotch tape on one side of the card, then another on the other side so that both adhesive sides touch each other. You can make it easy on yourself by placing the tape on the card and trimming the excess with a razor blade, using the card edge as a guide.
Hope this works for you!
-Dan
