Re: uRCL* on HP15C Message #3 Posted by Luiz C. Vieira (Brazil) on 29 Dec 2012, 6:09 p.m., in response to message #1 by Csaba Tizedes (Hungary)
Hi.
I saw the thread pointed by the link (just saw, could not understand neither translate) but there is a program listing like this one: LBL B
ENTER
ENTER
MATRIX 1
uRCL C
X<->Y
RCL* C
RCL+ 9
RTN In fact, the uRCL C is a recall with matrix C element pointer being moved forward to the next element after its execution (applies to STO as well). Simply activate the USER mode (make sure the USER indicator is lit) and press [RCL][C] while in program mode. You'll seennnu 45 13 in the LCD, where nnn is the step number. The upper u actually replaces the regular - signal, which is the indication that after this operation, the matrix element pointer will move forward (to the next element). You can check it by inspecting R00 and R01 contents.
Anyway, this does not apply to the RCL or STO arithmetic, though. If you need to enter the RCL* C simply press [RCL][×] [C] (the [×] is the multiplication key) and you'll seennn-45,20,13 in the LCD.
Hope this is what you are searching for.
Cheers.
Luiz (Brazil)
Edited: 29 Dec 2012, 6:16 p.m.
