Debug4X and "divide by zero" when attempting build Message #1 Posted by Joe Veazey on 24 Nov 2012, 11:18 p.m.
I am trying to learn to use Debug4x, and using the simple example UserRPL project as a learning vehicle. I always get a "divide by zero" error message when I attempt to build the project, or send the UserRPL source to the emulated calculator.
I'm getting back into writing some software for my hp50g after ignoring it for several years. I need to write some software to assist with machining calculations, and I would like to use Debug4X, instead of writing the code directly on the calculator. My thumbs can't handle that much typing anymore.
I am sure it's just a user problem, but I've been messing with it for a couple of hours, and have had no luck.
Is there anything obvious I can try?
