Re: HP-85 Display Error on startup Message #4 Posted by Paul Berger (Canada) on 19 Nov 2012, 10:57 p.m., in response to message #3 by hogelmann
They are located on the the display PCB I looked at my 85A and they are MB8116 chips so are a standard 16K bit DRAM chip. They are in sockets near the bottom just left of the flyback transformer, on the display board on the left side of the CRT. They are U13, U14, U15, and U16 on that board. You could try reseating them but from what you said it sounds like one of the chips has failed. If you turns out you need one of these chips I probably have some that would be suitable that I could try in my 85 before sending them. you could further isolate by swapping around the DRAMs if one is bad and you move it the symptom should change.
Yes the half byte (nibble) wide memory is a bit odd but I would guess it was done since it would fit a standard part and would reduce the chip count. the way the display buffer seems to be arranged the memory is only accessible through the display controller so there would be no convenient way for the self test to find problems with the display memory. You will find the service guide for the 85s on the HP Computer Museum website in Australia along with a lot of other good information.
