Re: Optimization questions - HP-15C Message #11 Posted by Thomas Klemm on 30 Oct 2012, 5:49 a.m., in response to message #9 by Marcel Samek
Hi Marcel
You found a bug in the script that generates the listing. For further details, please consult the following article:
Effective Computer-aided Calculator Programming - Part 1 - Voyager
The following patch can be applied to fix the script:
2812,2821c2812,2821
< ff00 | LBL .0 | - 42,42,.0 |
< ff01 | LBL .1 | - 42,42,.1 |
< ff02 | LBL .2 | - 42,42,.2 |
< ff03 | LBL .3 | - 42,42,.3 |
< ff04 | LBL .4 | - 42,42,.4 |
< ff05 | LBL .5 | - 42,42,.5 |
< ff06 | LBL .6 | - 42,42,.6 |
< ff07 | LBL .7 | - 42,42,.7 |
< ff08 | LBL .8 | - 42,42,.8 |
< ff09 | LBL .9 | - 42,42,.9 |
> ff00 | LBL .0 | - 42,21,.0 |
> ff01 | LBL .1 | - 42,21,.1 |
> ff02 | LBL .2 | - 42,21,.2 |
> ff03 | LBL .3 | - 42,21,.3 |
> ff04 | LBL .4 | - 42,21,.4 |
> ff05 | LBL .5 | - 42,21,.5 |
> ff06 | LBL .6 | - 42,21,.6 |
> ff07 | LBL .7 | - 42,21,.7 |
> ff08 | LBL .8 | - 42,21,.8 |
> ff09 | LBL .9 | - 42,21,.9 |
As far as I know the HP emulator is based on Nonpareil so it might be that you can save the state oft the calculator to a file and retrieve it from there. Nonpareil uses a gziped XML-file but you can just use the plain XML-file as well. The script "vcomp" allows to compile programs for the voyagers to this format and to list them as well. And there are some other features like macros.
Meanwhile your program has finished and produced the correct result! Wow, I'm impressed! Congratulations!.
This is the listing of your sudoku-program after correcting the script:
001 - 42,21, 0 LBL 0 042 - 45 0 RCL 0 083 - 44 3 STO 3 124 - 16 CHS 165 - 45 2 RCL 2
002 - 10 / 043 - 43, 6, 3 F? 3 084 - 3 3 125 - 44 1 STO 1 166 - 32 9 GSB 9
003 - 43 36 LSTx 044 - 16 CHS 085 - 10 / 126 - 42,21,.0 LBL .0 167 - 45 3 RCL 3
004 - 34 x<>y 045 - 40 + 086 - 43 44 INT 127 - 1 1 168 - 32 9 GSB 9
005 - 42 44 FRAC 046 - 34 x<>y 087 - 45 2 RCL 2 128 - 32 6 GSB 6 169 - 45 4 RCL 4
006 - 20 x 047 - 36 ENTER 088 - 3 3 129 - 45 7 RCL 7 170 - 32 9 GSB 9
007 - 43 34 RND 048 - 2 2 089 - 10 / 130 - 32 7 GSB 7 171 - 43, 6, 2 F? 2
008 - 43 32 RTN 049 - 6 6 090 - 43 44 INT 131 - 45 7 RCL 7 172 - 22 .9 GTO .9
009 - 42,21, 1 LBL 1 050 - 32 3 GSB 3 091 - 3 3 132 - 43,30, 1 TEST 1 173 - 45 6 RCL 6
010 - 36 ENTER 051 - 44 24 STO (i) 092 - 20 x 133 - 32 14 GSB D 174 - 32 14 GSB D
011 - 36 ENTER 052 - 33 Rv 093 - 40 + 134 - 8 8 175 - 22 15 GTO E
012 - 2 2 053 - 9 9 094 - 44 4 STO 4 135 - 0 0 176 - 42,21,13 LBL C
013 - 6 6 054 - 40 + 095 - 8 8 136 - 45 1 RCL 1 177 - 1 1
014 - 32 3 GSB 3 055 - 32 5 GSB 5 096 - 45 3 RCL 3 137 - 43,30, 6 TEST 6 178 - 16 CHS
015 - 45 24 RCL (i) 056 - 43 32 RTN 097 - 30 - 138 - 22 .0 GTO .0 179 - 32 6 GSB 6
016 - 43 32 RTN 057 - 42,21, 7 LBL 7 098 - 13 10^x 139 - 1 1 180 - 43,30, 1 TEST 1
017 - 42,21, 3 LBL 3 058 - 42, 4, 6 x<>6 099 - 44 5 STO 5 140 - 16 CHS 181 - 22 13 GTO C
018 - 40 + 059 - 44 0 STO 0 100 - 45 2 RCL 2 141 - 44 1 STO 1 182 - 45 6 RCL 6
019 - 44 25 STO I 060 - 45 2 RCL 2 101 - 1 1 142 - 42,21,15 LBL E 183 - 43, 4, 3 SF 3
020 - 33 Rv 061 - 1 1 102 - 7 7 143 - 8 8 184 - 32 14 GSB D
021 - 43 32 RTN 062 - 7 7 103 - 32 4 GSB 4 144 - 0 0 185 - 43, 5, 3 CF 3
022 - 42,21, 5 LBL 5 063 - 32 3 GSB 3 104 - 44 6 STO 6 145 - 45 1 RCL 1 186 - 22 .9 GTO .9
023 - 44 0 STO 0 064 - 45 24 RCL (i) 105 - 45 2 RCL 2 146 - 43,30, 5 TEST 5 187 - 42,21, 9 LBL 9
024 - 1 1 065 - 45 6 RCL 6 106 - 8 8 147 - 43 32 RTN 188 - 32 1 GSB 1
025 - 30 - 066 - 45 0 RCL 0 107 - 32 4 GSB 4 148 - 1 1 189 - 45 0 RCL 0
026 - 2 2 067 - 30 - 108 - 44 7 STO 7 149 - 32 6 GSB 6 190 - 10 /
027 - 34 x<>y 068 - 45 5 RCL 5 109 - 43 32 RTN 150 - 45 7 RCL 7 191 - 43 44 INT
028 - 14 y^x 069 - 20 x 110 - 42,21, 4 LBL 4 151 - 43,30, 1 TEST 1 192 - 2 2
029 - 42, 4, 0 x<>0 070 - 40 + 111 - 32 3 GSB 3 152 - 22 15 GTO E 193 - 32 0 GSB 0
030 - 43 32 RTN 071 - 44 24 STO (i) 112 - 45 24 RCL (i) 153 - 32 7 GSB 7 194 - 43,30, 1 TEST 1
031 - 42,21,14 LBL D 072 - 43 32 RTN 113 - 45 5 RCL 5 154 - 42,21,.9 LBL .9 195 - 43, 4, 2 SF 2
032 - 32 5 GSB 5 073 - 42,21, 6 LBL 6 114 - 10 / 155 - 9 9 196 - 33 Rv
033 - 45 2 RCL 2 074 - 44,40, 1 STO+ 1 115 - 43 44 INT 156 - 45 6 RCL 6 197 - 33 Rv
034 - 32 12 GSB B 075 - 45 1 RCL 1 116 - 1 1 157 - 43,30, 5 TEST 5 198 - 9 9
035 - 45 3 RCL 3 076 - 9 9 117 - 0 0 158 - 22 13 GTO C 199 - 40 +
036 - 32 12 GSB B 077 - 10 / 118 - 32 0 GSB 0 159 - 1 1 200 - 32 5 GSB 5
037 - 45 4 RCL 4 078 - 43 44 INT 119 - 43 32 RTN 160 - 40 + 201 - 43 32 RTN
038 - 32 12 GSB B 079 - 44 2 STO 2 120 - 42,21,11 LBL A 161 - 32 7 GSB 7
039 - 43 32 RTN 080 - 45 1 RCL 1 121 - 43, 5, 2 CF 2 162 - 45 6 RCL 6
040 - 42,21,12 LBL B 081 - 9 9 122 - 43, 5, 3 CF 3 163 - 32 5 GSB 5
041 - 32 1 GSB 1 082 - 32 0 GSB 0 123 - 1 1 164 - 43, 5, 2 CF 2
Edited: 30 Oct 2012, 5:53 a.m.
