Re: Needing help with my 48s Message #4 Posted by Randy on 2 Sept 2012, 10:42 a.m., in response to message #2 by Reth
Soak it up to the screen in clean water for a day. Then leave it to dry for a couple of days. If it still doesn't work, go get another one, they aren't expensive these days.
IMO, the first bit of advise is incorrect, the second, spot on.
A water bath will do nothing, you'll need the vibration of an ultrasonic cleaner and a surfactant cleaning agent to get the offending bits of conductive material out of the key dome areas. In the end, you may get a few more months or years of use out of the unit but ultimately, it is time to replace.
