Finally Success Message #2 Posted by xset on 30 Aug 2012, 12:27 p.m., in response to message #1 by xset
I managed to flash HP 30b to WP 34s !
I have Seeeduiono Mega, which i set to 3v mode.
It has FTDI chip on board. All you need to get flashing tool - to connect right pins (Tx0 Rx0 GND 3V3).
As far HP 30b pinout - it seems to be same as HP 20b.
J35 - Calculator In (Rx0 on Arduino)
J33 - Calculator Out (Tx0 on Arduino)
J31 - Vcc (3v out)
J36 - ERASE (when asked, connect to 3v3 output on Arduino)
J34 - GND (Connect to GDN on Arduino)
J32 - RESET (just use button above)
Check if Arduino (Seeeduino) talks on 3v levels on Rx0 Tx0 !!!
I found BH 6-pin connector and plugged 3 wires to pins (J35 J33 J34)
Previosly I erased firmware according WP 34s flashing guide.
Then I started MySamba and pressed 6-pin connector to contacts and finally it WORKED !
I got my WP 34s. Now i am thinking about stickers and how to open the case to solder quartz in.
