ArcTan without calculator Message #1 Posted by PatrickR on 14 Aug 2012, 5:42 a.m.
I had a situation yesterday that I would have solved by whipping out the DM15, but I had forgotten it, so manual calculation was the only option. I must though humbly admit that I utterly failed.
I wonder how I should have done.
We had a BBQ at a friend, who was constructing a new shed. The roof was not yet finished and we starting talking about roofing materials, but then came into that depending on the roof angle, there is a need for an underlayer. And then we wanted to know the roof angle...
We got as far as seeing it as a right angled triangle were the base is 3 and the height is 1, the side thus sqrt(10). Thus we only needed to calculate arctan(1/3) to know the roof angle. (I later put this to my neighbour who was a carpenter, he knew by heart several angles that you have when triangle height is 1 and base is an integer).
No calculators at the house. No smartphones. Nobody wanted to go in to boot up a computer.
Everyone pondered over the evening about how to solve this (series expansions: but who remembered the formula, integrals: something with 1 over a square root of something).
In the end, several calculations leading to nowhere, we had to give up and ring one of the kids who opened a Wolfram Alpha tab (what a computation overkill).
I don't know the arc trig or the regular trig expansions by heart, was there a way this could be solved logically with pre-calculus math?
Edited: 14 Aug 2012, 5:44 a.m.
