Re: Voyager battery installation sequence Message #10 Posted by Raymond Del Tondo on 10 Aug 2012, 9:16 p.m., in response to message #8 by Randy
Quote: Hold the calculator vertically so #1 is at the bottom position of the three cells. Using gravity, you stack them vertically starting with #1. It is the same orientation and procedure for the Pioneers as well. The purpose is to reduce the chance of memory loss.
A small correction. If I change batteries in the Voyagers, I usually just flip the unit around so that the batt compartment is in the upper left corner, and then insert the batts with plus pointing to the _left_, and the spring is on the left. On the Pioneers, I flip the unit around, and the batt compartment is on the top edge. Then I insert batteries with plus pointing to the _right_ , since the spring is on the right side.
I always insert the batts with the same hand, so moving the calcs into a position where both springs (Voyagers and Pioneers) are south seems very unergonomic for me, since in your example the Voyagers batt compartment would be on the lower left side, and the Pioneer's batt compartment would be on the mid to upper right side.
Aside from that, the German manual does not mention any insertion order. It only says that the plus pole of each battery has to point to the nearest rubber foot. Relevant pages are 230 - 233 in manual 00011-90002 German Rev. B 2K-7.83 . The photos in the manual are from the first implementation with two 3-finger springs.
Edited: 10 Aug 2012, 9:27 p.m.
