Re: HP42S Message #3 Posted by Dale Reed on 21 July 2012, 1:42 p.m., in response to message #2 by Gerson W. Barbosa
Forgive me if I missed it, but I didn't see a good description of using these keys for program editing and debugging in the 42s.pdf document. The descriptions in the comprehensive list ("move the program pointer") are a bit less than helpful for a new programmer.
On my HP-25, they work like this:
In PROG mode:
SST moves to and displays the next program step.
BST moves to and displays the previous program step.
You can use these to scroll through your program line by line for editing, just like using the up-arrow and down-arrow in a text editor. Since they are used for moving around in a program for editing (in PROG mode), you can't store them in a program. (You can't type up-arrow into a document, either, without using Character Map or some special ALT nnn code...)
In RUN mode:
When you press and hold SST (Single STep), it shows the current step of the program, and when you release it, executes that one step, then stops (with the program pointer at the next step), leaving the X stack register displayed.
When you press and hold BST (Back STep), it moves to and displays the previous step of the program, and when you release it, does not execute anything or restore anything.
These are used in RUN mode for debugging by watching your code execute one step at a time so you can compare the results of each step against what you expect.
On an HP-25, do this:
Switch to PROG. (Assume there is no program, or press (f) PRGM to clear it.)
01 (g) x**2 (shown in the display with row/column codes)
02 (g) pi
03 X
Switch to RUN. Press GTO 0 0 to return to the beginning of the program.
Key in a number. Press and hold SST -- you see the step number (01) and the keycode for (g) x**2. Release SST -- you see your number is now squared. Press and hold SST -- you see step number 02 and the keycode for (g) pi. Release SST -- you see the number pi in the display. (Your square has been pushed to y.) Press SST -- you see step number 03 and the keycode for multiply. Release SST -- you see the area of the circle whose radius you entered.
Probably way too wordy and redundant for most forum regulars, but I hope that explained it well enough for any programming newbies.
Dale
