HP42S power-on issue Message #1 Posted by David Persinger (US) on 10 July 2012, 9:01 a.m.
I have a new (for me) 42s. It seems to have an issue relating to turning on. Here is what happens.
- If it has been off for a while and I turn it on a message of "machine reset" appears on the screen.
- It can then be cycled off and on a few times without this happening, but eventually it will happen again even if it has not been off for very long.
- Then at some point it will not turn on again for some time. I'll come back to it several minutes later and it will turn on -- again with the "machine reset" message.
I could live with the machine reset, but it is a problem for it not to turn on at all sometimes.
I have removed the batteries. I have shorted the battery contacts for a few seconds.
Any thoughts? Can this be corrected? Do you think it is leading to complete failure of the unit?
