Re: Killed my 41-CX Halfnut Message #8 Posted by Luiz C. Vieira (Brazil) on 10 July 2012, 7:47 p.m., in response to message #7 by aj04062
Hi.
That would be great! Broken plastic posts will always be an issue...
About your halfnut: is it assembled already? Chances are you have already seen this picture, and in this case, you can see where did I connected an external 6Vcc battery pack (black for negative and red for positive, the ones going to bottom, not the red one going to the left) while performing some tests with this 'somehow dead' 41 halfnut. In fact, the little thing was alive after being disassembled and reassembled. I guess it was just some bad contact somewhere, and after soldering it all, it got back to business.
Hope you succeed.
Luiz (Brazil)
Edited: 10 July 2012, 7:50 p.m.
