Re: Another One Bites the Dust Message #21 Posted by Andrés C. Rodríguez (Argentina) on 25 June 2012, 3:20 p.m., in response to message #19 by Kees Bouw
In all continuous memory models, RAM chips are permanently connected to batteries, to receive the standby current (or voltage, if you prefer) needed to keep their contents; so the power switch in OFF position is not enough to prevent excessive voltage to reach these ICs if the batteries fail to act as a regulating device.
Again, please play it safe and recharge outside the calculator.
And, when using current (pun intended) NiMH batteries, which have a larger capacity compared to the original NiCd cells, a modern, external charger will be more convenient than the slow and non-smart charging circuit on the calculator.
