Re: 41CL V2 with V3 firmware Message #4 Posted by Angel Martin on 23 June 2012, 4:48 a.m., in response to message #1 by Gerry Schultz
V3 has additional module images but for those already included in V2 there's no address changes in flash between V2 and V3, Monte's always been very conscious about compatibility.
For instance if you use the CLLIB function in the CLUTILS module, it will list/plug any of the images for both revisions (and also for V1, the beta copy).
If you upgrade your YFNS to revision 3B you'll also have to use the IBDM, as it contains the address information for all images. This is used by the PLUGxx functions, transparent to the user so no need to worry about it - unless you want to ADD new images to flash, beyond the ones already included in V3.
Just remember that the IMDB has information about more images than those existing in the V2, so some of them won't work until you add them as well. Have a look at the CL manual, they have a pink background in the listing tables.
Some of the available address in V2 are now used in V3, therefore choose carefully not to add mew images into occupied places used by the IMDB.
