Powering the HP41 externally Message #1 Posted by Les Wright on 17 June 2012, 11:12 p.m.
I was contemplating fashioning a 4.8V external source for my 41's (basically 4 NiMH batteries in an external holder), and I am wondering how to hook it up.
With the battery holder out, I know that the leftmost contact is positive and the rightmost is negative, but I am wondering about the status of the middle two (negative and positive respectively) which bridge the middle two cells.
Are these two middle contacts merely a jumper to complete the circuit of all four cells? Or do they belong each to their own circuit?
In other words, when powering the 41 externally, can one use a single 4.8V source with a jumper across the middle two contacts, or does one need two separate 2.4V sources, one for the two left contacts and the other for the right two?
Forgive an ostensibly simple question. I just don't want to fry anything.
Les
