Re: Charging Current in HP97, 82143A, 82162A Message #5 Posted by Randy on 16 June 2012, 9:21 p.m., in response to message #1 by Les Wright
For the 97:
First off, it is not a constant current charger. It is similar in function to the woodstock charging circuit, charging current decreases as battery voltage rises. However, in the case of the 97, if the battery is bad or missing, there is a voltage clamp to prevent circuit damage. Also, the 97 varies the current depending upon the position of the on/off switch.
The circuit consists of a 10 vac transformer rectified by a full wave bridge. The dc output is connected to the battery in series with two resistors (in series). When the calculator is switched off, the effective resistance is 12.9 ohms, when on, 4.7 ohms. When the calculator is on and the display current exceeds a preset limit, the 4.7 ohm resistor is shunted by a pnp transistor to increase the available current.
Given those variables, it is not going to be an easy estimate.
I do not have schematics for the printers so I cannot comment on their charging circuits.
