Re: CLUTILS for XROM #31 YFNS instead of YFNZ? Message #4 Posted by Kerem Kapkin (Silicon Valley, CA) on 5 June 2012, 12:40 p.m., in response to message #2 by Ángel Martin
Hi Angel,
I know that version 3A allows to write to OS area which can also brick the calculator. So I wasn't sure if I should attempt this. I assume this process would be how to do it?
1- Clear Memory
2- MMUCLR
3- "YFNS" PLUG1L (Since I will write over YFNZ, I should use YFNS)
4- MMUEN
5- "007>80C" YMCPY
6- Patch using YPOKE
7- "80C>007" YFWR (Save the patched YFNZ back to its original location)
8- "YFNZ" PLUG1L
This is similar but modified for YFNZ of what I have done to patch YFNS, do you see any problem with this flow? I really want to use the CLUTILS with this 41CL but afraid of bricking it.
Thanks,
Kerem
