Re: NoV-64, CLUTILS 2H, and Library #4 Message #2 Posted by Ángel Martin on 22 May 2012, 1:30 p.m., in response to message #1 by M. Joury
Hi Marwan, looks like you´re having some issues but there´s a lot of moving parts in there so we´ll have to take it one at a time.
I don't have a NoV-64 so can't replicate your exact configuration. Also I'm not really familiar with the NoV-64 configuration details, like soft-settings on address 0x4041 - which may or may not have anything to do with this?
This is what I gather form your description:
- You're not seeing the CLUTILS_2H when burned into page #E, nor the YFNZ which is on the next page #F. I assume this is using CAT_2, but what about the CCD CAT'2?
-This is not the case for other modules, i.e. they show as expected also when burned in the same two pages,
A couple of initial actions and suggestions for troubleshooting:-
0. Make sure there isn't any XROM id# conflict (sorry I had to say it). CLUTILS uses XROM id#12, or 0x0C
1. Try it with CLUTLS alone, i.e. no other module in the NoV-64 (is it possible to not include the HEPAX?), say CLUTLS on lowest possible page#. Is it shown?
2. Do as it is but swapping pages #E and #F and see if there's any changes
3. burn the CLUTILS into a lowerer numbered page and see it the same pattern occurs with the other modules upstream.
There really isn't anything special or different to CLUTILS that would affect the CAT'2 operation, so ths is rather strange.
Let me know if that makes any difference. Also, let's solve the issue with the "standard" modules and worry about the Library#4 later on, if you don't mind.
'AM
