Re: [WP34S] Underlying format of manual.pdf v3.1? Message #13 Posted by Chris Tvergard on 20 May 2012, 5:53 p.m., in response to message #5 by Walter B
Walter,
I agree with you in every aspect of your entry and I did notice your interactive links. Your answers are exactly why I wanted to copy your links. And I do not mind receiving suggestions back from you at all since you have much more insight into this project than do I; which is, obviously, the exact very reason for why I go on the Forum to benefit thereof. Yes, had team known beforehand what they got themselves into they may have had second thoughts.
In an earlier entry Pauli aired the concept of an alphabetical sort of global catalog, which I referred to as the gCAT, with entries similar to those we use in internet browsers by keying in a few first characters. That would solve most of my problems at least. But I think that discussion may be DOA due to the programming efforts required on top of everything else.
In conclusion, I have decided that I really need your entire document on my tablet at all times as my needs and experience level change continuously. And thanks for all that work and thinking you put in this magnificent manual.
Until I receive my cable and become flash capable I'm kind of out of the evolutionary loop, however.
Thanks.
Chris
