Re: WP 34S - A Beginners Guide Message #49 Posted by Ciaran Brady on 24 May 2012, 4:22 a.m., in response to message #48 by Dominic Richens
Dominic
Incidentally - I noticed your comment above (regarding the shall we say, rather large font used I used in some of my examples). In the next draft which I've now 99% finished that issue (along with 14 other issues) is addressed (both for the RPN stack diagrams and also the bitwise logic operations (and, nand, or, nor, xor, xnor).
Regarding the preferred format issue I don't mind too much. Word is fine, RTF or PDF would work. The key thing is the content. I'd really want at least one or two worked examples perhaps demonstrating extremes of function behaviour and any abbreviations explained well enough so that I could understand more or less what was going on.
Its quite a difficult thing to do. I suspect I might be the same as you guys in the sense that I have a particular specialist area, which probably doesn't overlap with some of the library functions. So being able to articulate how they work well enough to explain the issue to a new user may need some hand holding
But - I'm definately up for the task - because it means I'll explore areas of the machine I haven't thus far looked at :-)
