Re: [WP34s] expert's catalog? Message #10 Posted by Katie Wasserman on 12 May 2012, 10:28 p.m., in response to message #8 by Marcus von Cube, Germany
I can understand your thinking on XEQ and ENTER. However, I was thinking more along the lines of an implied ENTER as soon as you hit the key.
For example:
Let's assume that the user catalog is invoked by some hidden, fast-to-type sequence like: <h><h><h>, then as soon as the the next key is pressed the user catalog command in that location (if there is one) will execute immediately.
If you had say, prtSTK, as the first user catalog command, then <h><h><h><A> would execute that Print Stack command immediately (or enter it in a program).
If there was a command that required an argument then the command sans argument would be shown on the display as if you had selected it from the standard catalog.
There would then be no reason that I can think of to exclude XEQ and ENTER from the possible mapping of user catalog functions to keys. EXIT, I suppose, would still need to be excluded to allow for an abort.
