Re: [WP34s] Stopwatch Message #15 Posted by pascal_meheut on 14 Apr 2012, 5:05 a.m., in response to message #14 by fhub
I implemented the function you wanted the day after you asked for it. I made this choice because it was faster to code and it seemed more logical.
And of course, we can always change it in the future should it prove inadequate.
Did you at least try it? Because if you are unhappy because people implement your suggestions quickly (and freely) but not exactly the way you would have done it, you should indeed consider to stop suggesting and to start coding yourself.
P.S: Pauli, Walter, Marcus & others including myself disagree often on the best way to implement something. Usually, the one implementing does what he thinks best after exchanging with the others...
This is exactly what happened here.
Edited: 14 Apr 2012, 5:06 a.m.
