Re: [WP-34s] Key-debouncing problem? Message #5 Posted by Daniel Vollmer on 11 Apr 2012, 2:26 p.m., in response to message #4 by Marcus von Cube, Germany
The calculator with the keys that are working flawlessly is exactly r2628, whereas the newer one is running 2758.
Unfortunately (as there is no way to reinstall the original HP firmware to compare) I can't be of further help, but I'm also likely putting it down as a hardware problem.
I'm probably imagining things, but with more use, the situation seems either improved, or I'm becoming more adept at pushing keys. :)
