HP-71B HP-IL module question Message #1 Posted by J-F Garnier on 30 Mar 2012, 11:32 a.m.
I found something strange in the HP-71B HP-IL module manual on the MoHPC DVD. In this edition January 1985 of the manual, on page 241, two error messages are mentionned (255021 "Low Battery" and 255029 "Medium protected") that are not in my own manual (edition of January 1984):
The most intriguing thing is that none of my various HP-IL modules have these error messages.
That's why I would like to do a small survey inside the HP-71B owner community:
can you try MSG$(255021) and MSG$(255029) and check if you get a message? You will need a LEX with the MSG$ keyword (for instance the Forth or text editor modules have it). Make sure the JPC LEX is not installed, since this LEX redefines the HP-IL messages.
I would be very interested to know if an updated HP-IL module did exist.
Thanks J-F
