Re: Got my DM-15CC Message #6 Posted by Paul Dale on 27 Mar 2012, 5:40 p.m., in response to message #5 by Jake Schwartz
The WP 13S has been mentioned :-)
The device is quite memory limited -- 32kb of flash and 8kb of persistent RAM. The latter is a lot larger than the 30b's 2kb of persistent RAM, however, the 30b also has 4kb of volatile RAM which we also use almost all of.
There is supposed to be padding for a large serial flash device on the PCB (I've not opened mine to check). If so, we'd have to implement most functionality as user code in that and only keep the basic floating point operations and the instruction interpreter in the on board flash.
Eric's DIY5 hardware seems like a better bet.
- Pauli
