Re: Clamshell Battery Contact Repair Message #7 Posted by aj04062 on 3 Mar 2012, 11:21 a.m., in response to message #3 by David Griffith
I think I am going to make it wider, at least a the top, to slide into the exiting groove. One of the challenges I had was using a sheet stock that was strong enough. The original metal contact is very thin and I don't think it would have been strong enough and I had a hard time getting some. This material I had.
This material is nearly the same thickness of the groove width. It fits snugly. With a little filing, it will fit.
What do you think?
