Re: Maintenance and Durability: From NIB to abused calculators Message #2 Posted by uhmgawa on 3 Mar 2012, 10:38 a.m., in response to message #1 by McAllan
I change electrolytic capacitor for modern film types.. Changing them in the PSU/inverter on many VFD seems to have an instant impact. Display is visible brigther and more crisp even nothing else was changed.
I suspect that's in part due to electrolytics of that vintage
not being generally available for switching converter
applications. Yet for battery powered VFDs converters of
relatively low energy it just may be electrolyte loss due to
age vs. internal heating.
The Ti-68 developed a fault at the flex cable connecting the display.. leading to display problems (in my case, no decimal point was displayed).
That can usually be repaired. Also I believe it's from a manufacturing defect right from the start only that it didn't show right from start. Yes of course the materials changed a little or the tracks it was bonded to oxidized underneath or similar because of insufficient heat setting and that's why there's now loose connections. But as said that can be fixed in many cases and without any special tools.
I've had mixed results trying to reset heat seal connections.
Part of the problem being the anisotropic adhesive is typically
thermosetting vs. thermoplastic and you may not be able to
soften it sufficiently to restore the contact and have joint
tension reliably maintained after the repair attempt. Keep
in mind if adhesive does flow in response to applied
heat, pressure should be maintained on the full heated area
so the tension in functional contacts isn't released resulting
in a worse problem.
The conductive tape used to establish a heat seal connection
consists of an adhesive impregnated with metallic plated
polymer balls. The joint is assembled and thermally set
typically by a hot bar bonding tool which most importantly
maintains full joint pressure until the adhesive has set (or
cooled in the case of thermoplastic adhesive). So a repair
attempt would need to do likewise to keep the plated
particles in tension between the conductor tape and pcb.
The most success I've had was using a bare (uncoated) metal
thumb tack head-down on the joint held by the stud in tweezers.
Move it around constantly while heating the back with a
soldering iron until you estimate it is sufficiently hot
and then remove the iron while maintaining pressure on the
tack. Agreed some experimentation is needed to get the
correct temperature for the adhesive (assuming it even will
reflow) short of destroying the polyester backing.
The recommended repair method for a heat seal connection is to
disassemble it and clean off the old conductive isotropic tape.
But with econo carbon ink printed heat seal conductors
mechanical removal can easily damage the carbon traces.
