Re: HP 15C LE programming, does CPU run fast? Message #2 Posted by Jeff O. on 12 Feb 2012, 5:13 p.m., in response to message #1 by designnut
Sam,
As far as I know, during entry of data or programs from the keyboard, the processor runs at full speed only during the time that a key is actually held down. So if you are quick with your keypresses, you should not use up too much battery life entering programs.
