Re: Limited run of blue key slant WP34S overlays Message #5 Posted by Bob Cortopassi on 8 Feb 2012, 3:28 p.m., in response to message #3 by Walter B
Walter,
As the designer of the original UI I must ask you urgently: please (!) print the labels on the prefix keys white and get that 'g' from Helvetica. Will calm my stomach significantly :-) TIA!
Done!
Besides, there's a very long tradition of g-shifted functions being printed blue...
I agree with this, as it is clearly a fact. Never the less, set your 15C or 41 or any number of other calculators next to your 34S. The similarity of the blue "g" key is much less noticeable than the glaring difference of the green key slants shining out at you.
Ideally, I'd like to keep g blue as well as the key front, but that would require firmware changes, and I've no doubt how you and the rest of the team would shoot me down if I proposed swapping the function (and keycodes all over the place) of the g and h shift keys.
Thanks for your thoughts, Walter, and all the hard work that got us to this point. Customizing wouldn't be possible if you and the team hadn't first created it.
Bob
