Re: go41cx overlay Math module Message #4 Posted by Olivier De Smet on 7 Feb 2012, 3:44 a.m., in response to message #3 by Vincent Weber
Key entry now useable at speed greater than 1, even works very well at x32 or max speed (around x50 for my slow motorola defy), but PSE and CAT are accelerated too
Fullnut display is done (sandbox is ok), but with the same restriction as real hardware :)
Printer is done, just some limitation about the size of the paper ...
Hepax support (up to 32 KB : 4 8KB modules) with relocation of the rom is done
I added CV support to allow more modules if you don't need XF and Time. But you can still plug XF and Time modules in the CV if needed
I added a CCD-OSX with special addressabilities : look for free page from 3 to 7 then from 15 to 8 :) So you can have a CX with printer (page 6), Hepax (page 7), 3 8K modules (ports 1, 2 and 3), CCD page 15 and a 4K rom module in port 4 (page 14), only page 4 is free (as usual). it gives 48 KW rom, 24 KW hepax ram, 600 regs XF and a 4 KW application pac :)
For the graphical overlays, it's possible, but it is a major rework of the keypad part ...
I hope to post this v1.2 on market tomorrow.
Olivier
