New release of go41cx Message #1 Posted by Olivier De Smet on 30 Jan 2012, 8:19 a.m.
Release 1.1.0
This one correct a timer bug (now, 'shift' ON works nicelly) and add a new config panel. You can manage :
- States of emulator: save as, load, export/import, ...
- Modules: plug, import/export, infos, ...
- Raws: load, import/export, infos, ...
- Programs: save from main memory to a raw file
- Overlays: load, import/export, ...
- XMem: load, save, import/export, ...
- Regs: display data regs, buffers, program, system, xmem, ...
Overlays are just text files, 70 lines max, 2 lines per key, first for top label, second for shifted label. "null" means no change.
Import/export permit to load/save from the internal files of the application and 'Download' directory of your sd-card, so you can download or mail files.
Olivier
Edited: 30 Jan 2012, 8:22 a.m.
