15CLE disassembly / reassembly recommendations? Message #1 Posted by Thomas Chrapkiewicz on 20 Dec 2011, 11:53 a.m.
Has anyone disassembled a 15CLE?
Removing the back is simple - only the 6 screws.
I've noticed that the PCB is retained with heat stakes.
If and when I remove these I would like some ideas on the proper screws to re-retain the PCB.
Thanks in advance,
TomC
