Re: 41CL - Shut Off that Auto-Turn Off Message #12 Posted by geoff quickfall on 21 Dec 2011, 4:01 p.m., in response to message #11 by M. Joury
probably apparent from the above postings but two separate "ON" definitions are discussed:
The "ON/USER" key which under normal circumstances is not
assignable. However on the CX this toggle key and the PRGM/ALPHA
key are reassigned in ED mode. I think I remember that synthetics
may be able to access those key locations.
The "ON" function whose sole purpose is to overide the timed out
"OFF" function by toggling flag 44. This flag, when not set, turns
the calculator 'off' after 10 minutes. When set, the calculator
stays 'on' indefinitely (battery dependent) until selected off
with the toggle switch. I cannot remember if it is set
to 'off' at each toggle 'off' cycle.
Cheers, Geoff
Edited: 21 Dec 2011, 4:06 p.m.
