Re: 9120 printer paper Message #3 Posted by David Ramsey on 28 Nov 2011, 7:32 p.m., in response to message #1 by Dave Brown Christchurch NZ
I would like to buy a few rolls (or even a case; your 2005 message mentions "many cases") of paper. The zinc oxide electrosensitive paper is unique to this machine, as far as I can determine, and is quite different from the still-available aluminized paper.
(In case anyone's interested: a printer "prints" on the more common aluminized paper by actually vaporizing the thin layer of aluminum, exposing the black polyvinyl alcohol layer underneath. The 9120 printer is designed for zinc oxide paper, which has the advantage of being white(ish) rather than silver. The zinc oxide layer is not vaporized but is reduced back to zinc by the electric current, resulting in dark brown print on a white background. NOBODY makes this kind of paper any more, although there are "premium" copy papers that use zinc oxide coatings for its bright white appearance. These won't work in the 9120 since they lack a conductive layer underneath the oxide coating.)
Edited: 28 Nov 2011, 7:33 p.m.
