Re: Another Red Dot on TAS. Is it or is it not ? Message #8 Posted by Michael de Estrada on 1 Nov 2011, 7:41 p.m., in response to message #7 by aj04062
I have a Version 4 with the wider upper keys with the legends on them that has a "split" battery tray, so I don't think this is definitive evidence of the version of an HP 35. I think if you look really closely at the middle section of the case that forms the battery tray and connects the battery contacts, it is actually always two pieces, however, sometimes there is no visible gap. This gives the false impression that it has been molded as a single piece. More telling is the serial number which is affixed to the middle section and appears to be original.
