Re: WP34s -- not turning on after flash Message #10 Posted by David Persinger (US) on 1 Nov 2011, 8:30 p.m., in response to message #9 by Jeff O.
Problem resolved!
Thank you Marcus, Gene, Dominic, and Jeff!
The problem was that when I downloaded calc.bin I right clicked and "save link as" on the calc.bin file. The resulting file was only 8k in size. The correct file would be ~121k. This 8k file would give the appearance of flashing but obviously would not work.
The proper method of downloading from the SVN page is to double-click the calc.bin file then select the download link.
It is interesting that even flashing the correct file did not solve the problem. I had to flash the original 30b rom back into the unit and then reflash with the WP34s rom. The unit worked just fine after that.
Also the lead to use MySamba.exe was very helpful, it is much easier to use and very fast.
Wonderful support from all you guys. What a joy. Thank you!
David
