Re: hp12C capability Message #3 Posted by uhmgawa on 13 Oct 2011, 11:29 p.m., in response to message #2 by Jeff O.
Quote: Is 128 kB enough?
For an AVR target a KEMU config including 11c/12c/15c/16c support
weighs in at:
/usr/bin/avr-size kemu_m1284p.elf
text data bss dec hex filename
51498 162 2239 53899 d28b kemu_m1284p.elf
Note this in on a modest 8-bit AVR core which isn't exactly
the runtime architecture Dennis Ritchie had in mind. So I'd
expect ARM thumb code to do considerably better. Note however
the firmware occupies the lion's share of flash, thus any
reduction due to use of a sane runtime architecture will be
proportional to actual emulator code.
Even a 64KB sam7l would suffice if the above assumption holds.
Interestingly 24-28KB of flash is more than sufficient for a
single 15c configuration, and a 12c flash footprint would
further reduce that by 7.5KB. I'd expect quite a bit of elbow
room could be found in the sam7l128 used in the encore 12c/15c.
RWM (bss + data above) however would need to be partitioned
between the 2KB of battery backed and 4KB volatile regions.
But I think that is doable. Other features such as a CLI
interface and support (mapping the segment display to ascii,
etc..) are included in the above image, the RWM storage
for which doesn't need to be persistent over power off
periods or can be deconfigured altogether.
