Re: HP 15c LE Display timing issues? Message #5 Posted by Mike Fikes on 2 Oct 2011, 10:55 a.m., in response to message #1 by Michael Kussmaul
With respect to Michael's question:
On the original 15C, the current row/column status message (when in matrix entering mode) is only shown for as long as you hold down the target matrix key (for example, while holding down the "A" key in the sequence STO A). (Unless, of course, 3 seconds elapse, resulting in cancellation / null.)
So, even on the original 15C, if you hit STO A and don't hold down the "A" key but simply press and release, you won't have time to read the status message, and may only see it briefly flash on the display.
