Re: HP 15c LE - Extended PSE Functionality? Message #5 Posted by Dave Britten on 30 Sept 2011, 10:31 a.m., in response to message #4 by Eddie W. Shore
Same here. Either you want the program to run fast and unattended, in which case PSE will just slow it down, or you want to get a series of intermediate results, in which case PSE will be too rushed. It might be handy for debugging, but R/S and SST are probably better options.
Just use this instead of PSE:
F? 7
R/S
Then if you have flag 7 set, your program will stop to show you intermediate results, otherwise it will just keep going. If you want to get really fancy, you could have it optionally put all the sequential results into a matrix, or series of registers so you can go back to them afterward. Maybe I'll do this to my prime factors program.
Edited: 30 Sept 2011, 10:52 a.m. after one or more responses were posted
