Re: HP 11C suddenly won't turn on Message #3 Posted by Antonio Petri (UK) on 20 Sept 2011, 3:30 p.m., in response to message #2 by uhmgawa
Thank you for your detailed diagnosis. It happens that after about 8 hours since I removed the batteries the calculator is working ok again, I haven't done anything but putting the batteries back in. Yes, the "Pr Error" message stayed even when the calculator wouldn't respond to any key press; it disappeared when I removed the batteries for the first time. After putting back the batteries after about 15 minutes the calculator didn't turn on at all. So, I understand that, if it happens again, I will have to short the batteries' contacts, as you suggest, or... wait 8 hours again!
Thank you again,
Antonio
